本页主题: HELP:Does anyone know what is "cometic grinding" for vessel fabrication 打印 | 加为IE收藏 | 复制链接 | 收藏主题 | 上一主题 | 下一主题
skyisblue
发帖: 56
威望: 3 点
金钱: 34 机械币
Hi all ,
I am novice here. So right now for me the main job is to read and get familiar with all the technical documents about our equipments.
And there is a term here which I am not sure what kind of procedure it is.
Here is the original sentence from the Hydrostatic test procedure for a seawater filter:
"All fabrication has been completed, except for operations which could not be performed prior to the test as such weld end preparation, cosmetic grinding on the base materical which does not affect the require thickness ."
"cosmetic grinding" -what it is ? Is it some kind of polishing in the vessel' surface?
Can any one help me get the picture here?
Thank you and best regards. And I will wait for your response on line.
PS : I am Chinese . And the reason why I type this in English is my system is English vesion.so...I have no other choices.
顶端 Posted: 2007-11-28 14:42 | [楼 主]
danielwong
级别: 工程师
发帖: 664
威望: 7 点
金钱: 8 机械币
应是“外观打磨”
本帖最近评分记录:
  • 金钱:+3(mllwhj) 鼓励鼓励。谢谢参与
  • 顶端 Posted: 2007-11-28 14:49 | 1 楼
    hdmpscb
    发帖: 41
    威望: 3 点
    金钱: 1212 机械币
    应该是磨外圆或或磨削表面
    本帖最近评分记录:
  • 金钱:+2(mllwhj) 鼓励技术讨论
  • 顶端 Posted: 2007-11-28 14:52 | 2 楼
    kylin_4567
    级别: 工程师
    发帖: 887
    威望: 13 点
    金钱: 613 机械币
    “所有的制造已经完成,除了不能预先进行的工作,比如焊接的准备工作、并不会影响基础材料表面厚度的磨削工作”
    cosmetic grinding
    我认为这里代表表面的,外观的磨削。
    打磨也许比较贴切
    本帖最近评分记录:
  • 金钱:+4(mllwhj) 鼓励技术讨论
  • 顶端 Posted: 2007-11-28 14:59 | 3 楼
    skyisblue
    发帖: 56
    威望: 3 点
    金钱: 34 机械币
    Thanks a lot. I really learned something from you.
    顶端 Posted: 2007-11-28 15:07 | 4 楼
    pinkparasol
    发帖: 36
    威望: 5 点
    金钱: 12 机械币
    同意。打磨的说法。 那么 “weld end preparation” 该怎么理解呢。 是焊接末端的准备工作么
    顶端 Posted: 2007-11-28 15:08 | 5 楼
    kylin_4567
    级别: 工程师
    发帖: 887
    威望: 13 点
    金钱: 613 机械币
    Quote:
    引用第5楼pinkparasol于2007-11-28 15:08发表的  :
    weld end
    词组
    表示焊接的意思
    不用把end翻译出来
    顶端 Posted: 2007-11-28 15:20 | 6 楼
    higherfly
    级别: 助工
    发帖: 339
    威望: 2 点
    金钱: 1063 机械币
    同意外观打磨的说法
    因为cosmetic 有装饰、化妆的意思,后面还说grinding      does not affect the
    require thickness .磨的量应该很少,光饰磨-类似于抛光
    本帖最近评分记录:
  • 金钱:+3(mllwhj) 鼓励技术讨论
  • 顶端 Posted: 2007-11-28 16:42 | 7 楼
    ship200
    级别: 工程师
    发帖: 650
    威望: 20 点
    金钱: 140 机械币
    AWS A3.0中的一个类似解释:
    cosmetic weld bead: a weld bead used to enhace appearance. 由此理解这个就不难了
    本帖最近评分记录:
  • 顶端 Posted: 2007-11-28 21:26 | 8 楼
    mpj6710
    级别: 助工
    发帖: 387
    威望: 6 点
    金钱: 126 机械币
    cosmetic 化妆品,化妆
    grinding  打磨
    cosmetic grinding 可理解为“为了表面美观而进行的打磨”
    本帖最近评分记录:
  • 顶端 Posted: 2007-11-29 17:12 | 9 楼
    jinghuang76
    级别: 助工
    发帖: 350
    威望: 2 点
    金钱: 320 机械币
    管理提醒: (mllwhj)
    你给谁发短信? (2007-12-04 09:10)
    you are good at english ,I admire you very much ,it's a pleasure for me if you can help me
    顶端 Posted: 2007-12-03 21:50 | 10 楼
    winter_zhao
    发帖: 222
    威望: 2 点
    金钱: 513 机械币
    weld end preparation  焊后处理,因为本身焊接完毕后需要清渣、清理飞溅,修磨焊缝
    cosmetic grinding      为外观抛光修磨,入不锈钢奶腐蚀的需要做抛光处理,再者国外压力容器一般还要将焊缝打磨与母材平齐等要求
    顶端 Posted: 2007-12-17 10:48 | 11 楼
    xajh
    发帖: 10
    威望: 2 点
    金钱: 28 机械币
    weld end mean 'after welding'
    顶端 Posted: 2008-05-02 14:21 | 12 楼
    dlx555
    发帖: 102
    威望: 0 点
    金钱: 116 机械币
    http://www.jxcad.com.cn/?u=1275786 这是表面处理,我也同意外观打磨的解释
    顶端 Posted: 2008-05-04 17:29 | 13 楼
    zenglei
    发帖: 180
    威望: 0 点
    金钱: 13 机械币
    同意
    顶端 Posted: 2009-02-27 10:33 | 14 楼
    flywithyou
    级别: 助工
    发帖: 322
    威望: 2 点
    金钱: 6 机械币
    专业点应是"坡口准备"
    顶端 Posted: 2009-02-27 13:26 | 15 楼
    五月的小小猫
    级别: 助工
    发帖: 539
    威望: 5 点
    金钱: 1 机械币
    表面抛光!  原因:在焊接过程中焊道的表面是会产生一定的飞溅等缺陷的。表面抛光的目的就是消除外观缺陷!
    顶端 Posted: 2009-02-27 14:20 | 16 楼
    mg_jixie
    发帖: 139
    威望: 1 点
    金钱: 0 机械币
    Trust that it's very clear now,
    cosmetic grinding      为外观表面抛光修磨,
    顶端 Posted: 2009-02-27 14:55 | 17 楼
    huntervvvv
    发帖: 28
    威望: 2 点
    金钱: 0 机械币
    agree
    顶端 Posted: 2009-02-27 17:44 | 18 楼
    hg2005
    级别: 工程师
    发帖: 734
    威望: 2 点
    金钱: 4 机械币
    cosmetic grinding 为美观而进行的修饰性打磨。比如去除麻坑,压痕
    weld end preparation 焊接坡口准备--去除试压辅助用具-如试压封头--再打磨或机加工制备坡口。
    顶端 Posted: 2009-02-28 14:43 | 19 楼
    lgb222
    发帖: 177
    威望: 3 点
    金钱: -39 机械币
    Quote:
    引用第19楼hg2005于2009-02-28 14:43发表的  :
    I am sorry for repost the quotation for unfamiliar with the operation...
    what i want to say is that is there any bevel maching or preparation still need and permited to make when you get the hydro test stage?
    顶端 Posted: 2009-03-01 08:57 | 20 楼
    中国机械CAD论坛 » Technical English(or other languages) Forum
    Total 2.418068(s) query 4, Time now is:2010-02-09 15:24, Gzip enabled 浙ICP备06006389号
    Powered by PW v6.3.2 Certificate Code © 2003-08 PHPWind.com Corporation
